주요 콘텐츠로 건너뛰기
DeWALT Hammer Drill DW511 Power Cord Replacement
필요한 것
  1. DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: 1 단계, 이미지 1/3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: 1 단계, 이미지 2/3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Power Cord Replacement: 2 단계, 이미지 1/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 2 단계, 이미지 2/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 2 단계, 이미지 3/3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: 3 단계, 이미지 1/2 DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: 3 단계, 이미지 2/2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Power Cord Replacement: 4 단계, 이미지 1/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 4 단계, 이미지 2/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Power Cord Replacement: 5 단계, 이미지 1/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 5 단계, 이미지 2/3 DeWALT Hammer Drill DW511 Power Cord Replacement: 5 단계, 이미지 3/3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Power Cord Replacement: 6 단계, 이미지 1/1
    • With both wires free, the power cord is free from the trigger body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Murray
회원 가입일: 10/03/19
400 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 1,385
