소개
Welcome to the DeWALT Hammer Drill DW511 trigger replacement guide. The trigger is an important part of the drill that tells the drill when to power up and which direction to drill. You would want to replace the trigger because of a trigger jam that happens inside the trigger mechanism.
Caution should be taken when working with on the device. It needs to be unplugged before working on any part of the drill.
필요한 것
Firmly grab the body of the trigger.
Slowly pull the trigger until the entire body is out and only attached by wires.
Use an opening tool to lift up the spring holding down the brush.
Remove the brush from its holding.
With a pair of blunt nose tweezers, grab the red wire.
Carefully wiggle the wire loose until it comes out.
