주요 콘텐츠로 건너뛰기
DeWalt D26451 Power Switch Replacement
필요한 것
  1. DeWalt D26451 Power Switch Replacement, Power Cord: 1 단계, 이미지 1/1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Switch Replacement: 2 단계, 이미지 1/1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Switch Replacement: 3 단계, 이미지 1/1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Switch Replacement: 4 단계, 이미지 1/1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Switch Replacement: 5 단계, 이미지 1/1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  6. DeWalt D26451 Power Switch Replacement, Power Switch: 6 단계, 이미지 1/1
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  7. DeWalt D26451 Power Switch Replacement: 7 단계, 이미지 1/1
  8. DeWalt D26451 Power Switch Replacement: 8 단계, 이미지 1/1
    • Once the cap is removed, the switch and connectors should be exposed
  9. DeWalt D26451 Power Switch Replacement: 9 단계, 이미지 1/1
    • Remove both connectors from the switch
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shelby LeQuire
회원 가입일: 01/29/16
639 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 1,286
