소개
This guide will walk you through replacing the plastic arms holding the brushes in place. These are both located at the base of the brush motor and are required for electrical connection.
필요한 것
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
