주요 콘텐츠로 건너뛰기
DeWalt D28110 Brush and Spring Replacement
필요한 것
  1. DeWalt D28110 Brush and Spring Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: 1 단계, 이미지 1/1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Brush and Spring Replacement: 2 단계, 이미지 1/1
    • Use the edge of the spudger to loosen and remove the back panel.
  3. DeWalt D28110 Brush and Spring Replacement: 3 단계, 이미지 1/1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  4. DeWalt D28110 Brush and Spring Replacement: 4 단계, 이미지 1/1
    • Pull back the rear side of the back panel.
  5. DeWalt D28110 Brush and Spring Replacement, Brush and Spring: 5 단계, 이미지 1/2 DeWalt D28110 Brush and Spring Replacement, Brush and Spring: 5 단계, 이미지 2/2
    • Gently pull to disconnect brush connector.
  6. DeWalt D28110 Brush and Spring Replacement: 6 단계, 이미지 1/2 DeWalt D28110 Brush and Spring Replacement: 6 단계, 이미지 2/2
    • Use the edge of the spudger to slide the spring off its post.
  7. DeWalt D28110 Brush and Spring Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently remove the brush and cable.
결론
Kean Wee
회원 가입일: 01/22/15
495 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-6, Maness Winter 2015 Cal Poly, Team 18-6, Maness Winter 2015 회원
CPSU-MANESS-W15S18G6
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 32
전체 시간: 2,224
