소개
If you realize your battery charger for your drill is not charging, there may be a blown fuse which can be replaced by following this guide.
필요한 것
Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
bigboyf232 - 답글
