주요 콘텐츠로 건너뛰기
DeWalt DC970 Drill Assembly Replacement
필요한 것
  1. DeWalt DC970 Drill Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Drill Assembly Replacement: 2 단계, 이미지 1/1
    • Remove battery from drill.
  3. DeWalt DC970 Drill Assembly Replacement, Drill Assembly: 3 단계, 이미지 1/2 DeWalt DC970 Drill Assembly Replacement, Drill Assembly: 3 단계, 이미지 2/2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Drill Assembly Replacement: 4 단계, 이미지 1/1
    • Lay the drill on its side and gently lift the top half off it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Hamel
회원 가입일: 03/10/16
633 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G2
3 회원들
안내서 13개 작성하였습니다
댓글 2개
It's actually a torx #10 and obviously, you dont really need a torque wrench, I got mine apart with my pro kit with no problems.
Christopher Porter - 답글
where is the guide?
no mention of the speed selector or any other internal parts
fred rogers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 25
전체 시간: 1,926
