주요 콘텐츠로 건너뛰기
DeWalt DC970 Motor Replacement
필요한 것
  1. DeWalt DC970 Motor Replacement, Battery: 1 단계, 이미지 1/1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: 2 단계, 이미지 1/1
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: 3 단계, 이미지 1/2 DeWalt DC970 Motor Replacement, Drill Assembly: 3 단계, 이미지 2/2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: 4 단계, 이미지 1/1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: 5 단계, 이미지 1/1
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: 6 단계, 이미지 1/1
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: 7 단계, 이미지 1/1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan Hamel
회원 가입일: 03/10/16
633 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-2, Catania Spring 2016 UMass Dartmouth, Team 4-2, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G2
3 회원들
안내서 13개 작성하였습니다
댓글 3개
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - 답글
Thanks for the heads up on the wires
Daniel Randall - 답글
Is there a fix to replace brushes?
pmac086 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 36
전체 시간: 6,505
