주요 콘텐츠로 건너뛰기
DeWalt DCF885 Selector Switch Replacement
필요한 것
  1. DeWalt DCF885 Selector Switch Replacement, Battery: 1 단계, 이미지 1/1
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: 2 단계, 이미지 1/1
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: 3 단계, 이미지 1/1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: 4 단계, 이미지 1/1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: 5 단계, 이미지 1/1
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: 6 단계, 이미지 1/1
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: 7 단계, 이미지 1/1
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: 8 단계, 이미지 1/1
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: 9 단계, 이미지 1/1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: 10 단계, 이미지 1/1
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: 11 단계, 이미지 1/1
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: 12 단계, 이미지 1/1
    • Pull the selector switch out from the outer case.
결론
Brittney Dismuke
회원 가입일: 01/17/19
166 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 678
