주요 콘텐츠로 건너뛰기
DeWalt DCF887B Type 3 Spring Replacement
필요한 것
  1. DeWalt DCF887B Type 3 Spring Replacement, Spring: 1 단계, 이미지 1/1
    • Place the picker inside the first washer and lever it out of place.
    • Use a bit of strength to ensure that the collar doesn’t click back in the same place.
  2. DeWalt DCF887B Type 3 Spring Replacement: 2 단계, 이미지 1/2 DeWalt DCF887B Type 3 Spring Replacement: 2 단계, 이미지 2/2
    • Once you pop out the first washer with a slight gap in it, called a "hog ring," a plain washer will follow.
  3. DeWalt DCF887B Type 3 Spring Replacement: 3 단계, 이미지 1/1
    • Remove the collar by grabbing the outer rim and pulling it out gently with your fingers.
    • Once you remove the collar, place it on the side of the table with the shortest end pointing upwards.
  4. DeWalt DCF887B Type 3 Spring Replacement: 4 단계, 이미지 1/1
    • Remove the steel ball by popping it out with the picker, or ideally, grabbing it with a magnetic tool.
    • Use minimal force when popping the steel ball out to ensure that it doesn’t fly away.
    • Set the steel ball somewhere it won't roll away.
  5. DeWalt DCF887B Type 3 Spring Replacement: 5 단계, 이미지 1/1
    • Grab the broken spring and pull it out gently.
    • You might have to wiggle the spring back-and-forth during removal.
  6. DeWalt DCF887B Type 3 Spring Replacement: 6 단계, 이미지 1/1
    • Replace the steel ball.
    • Align the crook in the spring with the steel ball's hole in the spindle to install the new spring.
    • Compress the spring right back through the middle of the steel ball frame.
    • Make sure the steel ball is tensioned by the spring.
  7. DeWalt DCF887B Type 3 Spring Replacement: 7 단계, 이미지 1/1
    • Attach the collar over the spring.
    • Apply light pressure on the spring with your left hand to pop the collar back on top.
  8. DeWalt DCF887B Type 3 Spring Replacement: 8 단계, 이미지 1/1
    • With the collar facing up, add the plain washer back into the center of the collar, then the hog ring.
    • Press down on the hog ring along with the collar until you hear it "click" into place.
결론
Your impact driver should now be fully-functional!
다른 한 분이 해당 안내서를 완성하였습니다.
Leobardo Hernandez
회원 가입일: 02/28/22
178 평판
안내서 1개 작성함
University of Memphis, Team 2-2, Willis Spring 2022 University of Memphis, Team 2-2, Willis Spring 2022 회원
UM-WILLIS-S22S2G2
1 회원
안내서 1개 작성하였습니다
댓글 2개
Getting the hog ring back on is difficult. Is there a tool, besides picks, to help with this?
BRUCE BROWN - 답글
Nope, patience and diligence. Get one side of the ring completely seated and then slide slowly around the inside of it so widen it as you push down. 2 small drivers can help
eric arendale (ericofcourse) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 91
전체 시간: 3,995
