주요 콘텐츠로 건너뛰기
DeWalt DCS380 Blade Shaft Replacement
필요한 것
  1. DeWalt DCS380 Blade Shaft Replacement, Removing shoe and boot.: 1 단계, 이미지 1/1
    • Remove the battery before disassembly.
    • Remove the shoe by pressing the yellow button on the left side of the hand grip.
  2. DeWalt DCS380 Blade Shaft Replacement: 2 단계, 이미지 1/2 DeWalt DCS380 Blade Shaft Replacement: 2 단계, 이미지 2/2
    • Remove the two M8x18mm T20 bolts from the front plate.
  3. DeWalt DCS380 Blade Shaft Replacement: 3 단계, 이미지 1/1
    • Pull the front of the grip while holding the saw body in place.
  4. DeWalt DCS380 Blade Shaft Replacement, Blade Shaft: 4 단계, 이미지 1/2 DeWalt DCS380 Blade Shaft Replacement, Blade Shaft: 4 단계, 이미지 2/2
    • Remove the four M8x18mm T20 screws on the top of the gearbox.
    • Pull the top of the gearbox off and set the saw body aside.
  5. DeWalt DCS380 Blade Shaft Replacement: 5 단계, 이미지 1/2 DeWalt DCS380 Blade Shaft Replacement: 5 단계, 이미지 2/2
    • Remove the black plastic dust covers using the plastic pry bar.
    • Remove the two M5 lock nuts using a 5/16" socket.
  6. DeWalt DCS380 Blade Shaft Replacement: 6 단계, 이미지 1/2 DeWalt DCS380 Blade Shaft Replacement: 6 단계, 이미지 2/2
    • Turn the housing over and remove the two countersunk M5x17mm T20 bolts from the shaft yoke.
    • Remove the yoke.
  7. DeWalt DCS380 Blade Shaft Replacement: 7 단계, 이미지 1/2 DeWalt DCS380 Blade Shaft Replacement: 7 단계, 이미지 2/2
    • Pull the shaft out of the front of the housing.
    • Leave the shaft saddle in place over the holes in the cover.
    • Re-grease before re-assembly. If there are metal shavings or pieces of the broken shaft left in the gearbox make sure to remove them before re-greasing.
결론
Jonathan Hicks
회원 가입일: 01/17/19
725 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 18
전체 시간: 846
