주요 콘텐츠로 건너뛰기
DeWalt DW235G Drill Chuck Part Replacement
필요한 것
  1. DeWalt DW235G Drill Chuck Part Replacement, Chuck Component: 1 단계, 이미지 1개 중 1개
    • Identify the Hex nut within the inside of the chuck of the drill.
    • Insert the 4mm Allen key into the chuck to loosen the Hex nut.
    • The Hex nut is reversed threaded. To loosen the nut, simply twist the 4mm Allen key in the opposite direction.
  2. DeWalt DW235G Drill Chuck Part Replacement: 2 단계, 이미지 1개 중 1개
    • Re-insert the 4mm Allen key into the chuck after the Hex nut has been taken out.
    • Make sure that the 4mm Allen key is firmly in place inside the chuck.
  3. DeWalt DW235G Drill Chuck Part Replacement: 3 단계, 이미지 1개 중 1개
    • Using a hammer or blunt object, strike the 4mm Allen key in order to break loose the chuck from the body of the drill.
    • Make sure the drill is thoroughly secured before striking.
결론
To actually install the chuck replacement part, follow the guide in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Adam V
회원 가입일: 09/12/23
166 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 83
지난 30일: 209
전체 시간: 1,284
