주요 콘텐츠로 건너뛰기
DeWalt DW660 Bearings Replacement
필요한 것
  1. DeWalt DW660 Bearings Replacement, Bearings: 1 단계, 이미지 1/1
    • Pull off the depth guide.
    • If the guide doesn't come away easily, use a twisting motion to pull it from the tool.
  2. DeWalt DW660 Bearings Replacement: 2 단계, 이미지 1/3 DeWalt DW660 Bearings Replacement: 2 단계, 이미지 2/3 DeWalt DW660 Bearings Replacement: 2 단계, 이미지 3/3
    • Hold down lock #1 to prevent the motor from spinning.
    • While holding lock #1, hold down lock #2 as well.
    • Rotate lock #2 counterclockwise to unscrew the collet nut.
  3. DeWalt DW660 Bearings Replacement: 3 단계, 이미지 1/1
    • Remove the collet nut and the collet from the device.
  4. DeWalt DW660 Bearings Replacement: 4 단계, 이미지 1/2 DeWalt DW660 Bearings Replacement: 4 단계, 이미지 2/2
    • Unscrew the four 19mm T20 Torx screws on the motor shroud.
    • Carefully remove the shroud from the body.
    • When removing the shroud, the spring that operates lock #2 may pop out.
  5. DeWalt DW660 Bearings Replacement: 5 단계, 이미지 1/3 DeWalt DW660 Bearings Replacement: 5 단계, 이미지 2/3 DeWalt DW660 Bearings Replacement: 5 단계, 이미지 3/3
    • Unscrew the four 19mm T20 Torx screws on the side of the back end of the DW660.
    • Take apart the back two halves.
    • Using two fingers, pull the black and white power wires from the motor to completely disconnect the back half of the device.
  6. DeWalt DW660 Bearings Replacement: 6 단계, 이미지 1/2 DeWalt DW660 Bearings Replacement: 6 단계, 이미지 2/2
    • Lift the coiled spring from the back of the brush using a spudger.
    • While holding the spring out of the way, use a pointed spudger to slide the carbon brush up out of the guide.
    • Slowly release the brush spring. It will sit in the brush guide.
    • Repeat this step for the second brush.
  7. DeWalt DW660 Bearings Replacement: 7 단계, 이미지 1/1
    • Pull the rotor out of the front of the DW660.
    • Be very careful to make sure the rotor does not collide with the stator. The stator coils or the commutator can be damaged very easily.
  8. DeWalt DW660 Bearings Replacement: 8 단계, 이미지 1/1
    • Remove the snap ring from the bearing by using snap ring pliers.
    • This will take some force and the snap ring will act as a spring, so be careful to make sure the ring does not fly off the pliers.
  9. DeWalt DW660 Bearings Replacement: 9 단계, 이미지 1/1
    • Pull the black plastic bearing block off of the motor shaft.
    • Remove the ball bearing from the bearing block.
  10. DeWalt DW660 Bearings Replacement: 10 단계, 이미지 1/2 DeWalt DW660 Bearings Replacement: 10 단계, 이미지 2/2
    • Remove the rubber cap from the bearing.
    • Use the bearing puller to remove the bearing from the shaft.
    • When installing the new bearings, it may help to use a small hammer and a hollow circular pipe with the same outer diameter as the inner ring of the bearing.
결론
Ryan Owen Rheaume
회원 가입일: 04/03/15
405 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 UMass Dartmouth, Team 2-7, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G7
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
What size bearing does it take?
James Armstrong - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 791
