주요 콘텐츠로 건너뛰기
DeWalt DW660 Motor Brushes Replacement
필요한 것
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: 1 단계, 이미지 1/2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: 1 단계, 이미지 2/2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: 2 단계, 이미지 1/3 DeWalt DW660 Motor Brushes Replacement: 2 단계, 이미지 2/3 DeWalt DW660 Motor Brushes Replacement: 2 단계, 이미지 3/3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: 3 단계, 이미지 1/2 DeWalt DW660 Motor Brushes Replacement: 3 단계, 이미지 2/2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: 4 단계, 이미지 1/2 DeWalt DW660 Motor Brushes Replacement: 4 단계, 이미지 2/2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: 5 단계, 이미지 1/2 DeWalt DW660 Motor Brushes Replacement: 5 단계, 이미지 2/2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joseph Pacitto
회원 가입일: 03/23/16
239 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-7, Isaacson Spring 2016 UMass Dartmouth, Team 2-7, Isaacson Spring 2016 회원
UMASSD-ISAACSON-S16S2G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 19
전체 시간: 1,407
