소개
The power cord can simply be replaced by opening the back of the device and unscrewing the casing. Make sure that the device is not plugged in before working on it.
필요한 것
Using a T20 Torx Screwdriver, unscrew the four 19mm screws from the back casing.
After unscrewing, remove the back casing from the device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
