주요 콘텐츠로 건너뛰기
DeWalt DW920 Lock Switch Replacement
필요한 것
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: 1 단계, 이미지 1/1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: 2 단계, 이미지 1/1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: 3 단계, 이미지 1/1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: 4 단계, 이미지 1/1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: 5 단계, 이미지 1/2 DeWalt DW920 Lock Switch Replacement: 5 단계, 이미지 2/2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
결론
Stephen Rada
회원 가입일: 03/11/16
433 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G2
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
This guide was descriptive and easy to follow. Good job!
DankMemerino - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 268
