주요 콘텐츠로 건너뛰기
DeWalt DW920 Motor Replacement
필요한 것
  1. DeWalt DW920 Motor Replacement, Disassembly: 1 단계, 이미지 1/1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: 2 단계, 이미지 1/1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: 3 단계, 이미지 1/1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: 4 단계, 이미지 1/1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: 5 단계, 이미지 1/1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: 6 단계, 이미지 1/1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
결론
Stephen Rada
회원 가입일: 03/11/16
433 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G2
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 828
