소개
A non-functional rotation switch might be one of the many reasons your drill is not working as it should. This is a step-by step guide on how to replace the rotation switch. This is necessary when your drill isn't rotating and working. Using this guide, you will be able to fix your drill and continue to use it. To fix this you do not need any special skills. You can just follow this step by step process to get it done.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
