주요 콘텐츠로 건너뛰기
DeWalt DW920 Rotational Switch Replacement
필요한 것
  1. DeWalt DW920 Rotational Switch Replacement, Disassembly: 1 단계, 이미지 1/1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Rotational Switch Replacement: 2 단계, 이미지 1/1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Rotational Switch Replacement: 3 단계, 이미지 1/1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Rotational Switch Replacement, Rotational Switch: 4 단계, 이미지 1/1
    • Locate the rotational switch
  5. DeWalt DW920 Rotational Switch Replacement: 5 단계, 이미지 1/1
    • Carefully release the connection between the rotational switch and the motor assembly. This should be done carefully to ensure that the switch connection switch on the assembly is not damaged.
  6. DeWalt DW920 Rotational Switch Replacement: 6 단계, 이미지 1/1
    • Once the switch is freed from the assembly, firmly grip it between two fingers and lift it straight out of the drill frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron MacKinnon
회원 가입일: 04/06/16
241 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 8-2, Botvin Spring 2016 UMass Dartmouth, Team 8-2, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G2
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
Everything looks good on this guide, good job!
DankMemerino - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,359
