주요 콘텐츠로 건너뛰기
DeWalt DW936 Boot Replacement
필요한 것
  1. DeWalt DW936 Boot Replacement, Plastic Cover: 1 단계, 이미지 1개 중 1개
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Boot Replacement: 2 단계, 이미지 1개 중 1개
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Boot Replacement: 3 단계, 이미지 1개 중 1개
    • Remove Allen Key.
  4. DeWalt DW936 Boot Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Boot Replacement: 5 단계, 이미지 1개 중 1개
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Boot Replacement: 6 단계, 이미지 1개 중 1개
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Boot Replacement, Boot: 7 단계, 이미지 1개 중 1개
    • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
  8. DeWalt DW936 Boot Replacement: 8 단계, 이미지 1개 중 1개
    • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
  9. DeWalt DW936 Boot Replacement: 9 단계, 이미지 1개 중 1개
    • Pull the blade away from the body of the saw causing the blade and boot to detach.
  10. DeWalt DW936 Boot Replacement: 10 단계, 이미지 1개 중 1개
    • Pull the boot downwards away from the blade to detach it.
결론
작성자
1다른 기여자 명과 함께
Scott Weinhardt
회원 가입일: 01/25/17
603 평판
안내서 5개를 작성함
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 612
