주요 콘텐츠로 건너뛰기
DeWalt DW936 Plastic Cover Replacement
필요한 것
  1. DeWalt DW936 Plastic Cover Replacement, Plastic Cover: 1 단계, 이미지 1/1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Plastic Cover Replacement: 2 단계, 이미지 1/1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Plastic Cover Replacement: 3 단계, 이미지 1/1
    • Remove Allen Key.
  4. DeWalt DW936 Plastic Cover Replacement: 4 단계, 이미지 1/1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Plastic Cover Replacement: 5 단계, 이미지 1/1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Plastic Cover Replacement: 6 단계, 이미지 1/1
    • This is what the inside of the saw looks like.
결론
Scott Weinhardt
회원 가입일: 01/25/17
603 평판
안내서 5개 작성하였습니다
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 9
전체 시간: 370
