주요 콘텐츠로 건너뛰기
DeWalt DW936 Trigger Replacement
필요한 것
  1. DeWalt DW936 Trigger Replacement, Plastic Cover: 1 단계, 이미지 1개 중 1개
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Trigger Replacement: 2 단계, 이미지 1개 중 1개
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Trigger Replacement: 3 단계, 이미지 1개 중 1개
    • Remove Allen Key.
  4. DeWalt DW936 Trigger Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Trigger Replacement: 5 단계, 이미지 1개 중 1개
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Trigger Replacement: 6 단계, 이미지 1개 중 1개
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Trigger Replacement, Trigger: 7 단계, 이미지 1개 중 1개
    • The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
    • Pull up.
  8. DeWalt DW936 Trigger Replacement: 8 단계, 이미지 1개 중 1개
    • The trigger should be able to sit freely.
  9. DeWalt DW936 Trigger Replacement: 9 단계, 이미지 2개 중 1개 DeWalt DW936 Trigger Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift off the silver metal piece using tweezers.
    • Lift off each hook. (4 corners)
  10. DeWalt DW936 Trigger Replacement: 10 단계, 이미지 1개 중 1개
    • Pull plastic trigger out of the black plastic casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Scott Weinhardt
회원 가입일: 01/25/17
603 평판
안내서 5개를 작성함
Cal Poly, Team 8-2, Banghart Winter 2017 Cal Poly, Team 8-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
donald.mcguinnes - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 922
