주요 콘텐츠로 건너뛰기
DeWalt DW938 Clam Shell Replacement
필요한 것
  1. DeWalt DW938 Clam Shell Replacement, Clam Shell: 1 단계, 이미지 1/3 DeWalt DW938 Clam Shell Replacement, Clam Shell: 1 단계, 이미지 2/3 DeWalt DW938 Clam Shell Replacement, Clam Shell: 1 단계, 이미지 3/3
    • Use a torque bit screw driver to remove the T10 18.3 mm screw on the handle.
    • Use a torque bit screw driver to remove 6 T10 21.5 mm screws on the handle.
    • Insure power source is removed from tool.
    • Insure blade is removed from tool.
  2. DeWalt DW938 Clam Shell Replacement: 2 단계, 이미지 1/1
    • Carefully cut the safety sticker with a blade along the seam.
  3. DeWalt DW938 Clam Shell Replacement: 3 단계, 이미지 1/1
    • Remove the Clam Shell from the handle unit.
결론
Christopher Chin
회원 가입일: 03/08/17
316 평판
안내서 3개 작성하였습니다
IUPUI, Team S4-G4, Baechle Spring 2017 IUPUI, Team S4-G4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 한 개
do you know where I can find a clam shell just like this one?
file:///C:/Users/Tony/Desktop/clam%20shell1.jpg
Tony Lacour - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 588
