주요 콘텐츠로 건너뛰기
DeWalt DW938 Switch VSR Replacement
필요한 것
  1. DeWalt DW938 Switch VSR Replacement, Clam Shell: 1 단계, 이미지 1/3 DeWalt DW938 Switch VSR Replacement, Clam Shell: 1 단계, 이미지 2/3 DeWalt DW938 Switch VSR Replacement, Clam Shell: 1 단계, 이미지 3/3
    • Use a torque bit screw driver to remove the T10 18.3 mm screw on the handle.
    • Use a torque bit screw driver to remove 6 T10 21.5 mm screws on the handle.
    • Insure power source is removed from tool.
    • Insure blade is removed from tool.
  2. DeWalt DW938 Switch VSR Replacement: 2 단계, 이미지 1/1
    • Carefully cut the safety sticker with a blade along the seam.
  3. DeWalt DW938 Switch VSR Replacement: 3 단계, 이미지 1/1
    • Remove the Clam Shell from the handle unit.
  4. DeWalt DW938 Switch VSR Replacement, Switch VSR: 4 단계, 이미지 1/1
    • Lift the mechanical device off the pins of the clam shell.
  5. DeWalt DW938 Switch VSR Replacement: 5 단계, 이미지 1/2 DeWalt DW938 Switch VSR Replacement: 5 단계, 이미지 2/2
    • Remove the red and black trigger wires from the brush leads with the pliers.
  6. DeWalt DW938 Switch VSR Replacement: 6 단계, 이미지 1/2 DeWalt DW938 Switch VSR Replacement: 6 단계, 이미지 2/2
    • Remove the VSR trigger and the lock button.
결론
Christopher Chin
회원 가입일: 03/08/17
316 평판
안내서 3개 작성하였습니다
IUPUI, Team S4-G4, Baechle Spring 2017 IUPUI, Team S4-G4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 533
