소개
If the drill does not switch rotational direction, this guide will help you disassemble and replace the switch.
필요한 것
There should be 7 screws that are 21 mm long, remove them with a TorxT15 bit.
There should be 1 screw that is 18 mm long, remove it with a Torx T10 bit.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
