주요 콘텐츠로 건너뛰기
DeWalt DW997 Motor Replacement
필요한 것
  1. DeWalt DW997 Motor Replacement, Speed Switch: 1 단계, 이미지 1/2 DeWalt DW997 Motor Replacement, Speed Switch: 1 단계, 이미지 2/2
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Motor Replacement: 2 단계, 이미지 1/1
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Motor Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Motor Replacement: 4 단계, 이미지 1/1
    • Remove the other leg manually, it should easily come out.
  5. DeWalt DW997 Motor Replacement, Motor: 5 단계, 이미지 1/2 DeWalt DW997 Motor Replacement, Motor: 5 단계, 이미지 2/2
    • Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
  6. DeWalt DW997 Motor Replacement: 6 단계, 이미지 1/2 DeWalt DW997 Motor Replacement: 6 단계, 이미지 2/2
    • Pull off the two wires that connect the motor to the trigger.
    • Be careful while pulling the wires as they can tear.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 09/12/16
140 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 2,253
