주요 콘텐츠로 건너뛰기
DeWalt DW997 Trigger Replacement
필요한 것
  1. DeWalt DW997 Trigger Replacement, Trigger: 1 단계, 이미지 1/2 DeWalt DW997 Trigger Replacement, Trigger: 1 단계, 이미지 2/2
    • First remove the seven 21mm screws using a Torx T15 screw bit.
    • Then use a Torx T10 screw bit to remove the remaining 18mm screw.
    • After removing all of the screws, lift the cover off.
    • Do not attempt to pry the covers apart; doing so can cause the covers to crack.
  2. DeWalt DW997 Trigger Replacement: 2 단계, 이미지 1/1
    • Carefully remove the trigger pack by lifting the pack straight up.
  3. DeWalt DW997 Trigger Replacement: 3 단계, 이미지 1/1
    • The final step is to pull the wires off of the trigger by pulling the wire heads.
    • Be careful while taking off the wires as they can tear.
결론
Vanessa Duran
회원 가입일: 09/12/16
113 평판
안내서 1개 작성함
댓글 한 개
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
drillbatterycomau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 14
전체 시간: 1,861
