소개
The wound wires of a field coil can fail, causing a drill to function poorly or not at all. Use this guide to replace a broken field in the DeWalt DWD112.
필요한 것
Move the black wire clear from any obstruction.
Repeat this step for the white wire and the red wire.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
as a recommendation aimed at some or mark with a piece of ribbon cables disconnected the trigger with the contact number that corresponds to the rearm the drill going to not reverse the change control rotation.
