주요 콘텐츠로 건너뛰기
DeWalt DWE4011 Carbon Brushes Replacement
필요한 것
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: 1 단계, 이미지 1/1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: 2 단계, 이미지 1/1
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: 3 단계, 이미지 1/2 DeWalt DWE4011 Carbon Brushes Replacement: 3 단계, 이미지 2/2
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: 4 단계, 이미지 1/1
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: 5 단계, 이미지 1/1
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: 6 단계, 이미지 1/2 DeWalt DWE4011 Carbon Brushes Replacement: 6 단계, 이미지 2/2
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
결론
Congratulations! To put your device back together, simply reverse the above steps.
Kiera Sloan
회원 가입일: 04/03/19
145 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 32
전체 시간: 1,366
