주요 콘텐츠로 건너뛰기
DeWalt_D26451 Brake Replacement
필요한 것
  1. DeWalt_D26451 Brake Replacement, Pad: 1 단계, 이미지 1/3 DeWalt_D26451 Brake Replacement, Pad: 1 단계, 이미지 2/3 DeWalt_D26451 Brake Replacement, Pad: 1 단계, 이미지 3/3
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: 2 단계, 이미지 1/2 DeWalt_D26451 Brake Replacement: 2 단계, 이미지 2/2
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: 3 단계, 이미지 1/1
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: 4 단계, 이미지 1/1
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: 5 단계, 이미지 1/1
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
결론
Shelby LeQuire
회원 가입일: 01/29/16
639 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 31
전체 시간: 2,050
