주요 콘텐츠로 건너뛰기
Decorative Light Fixture Lightbulb Replacement
필요한 것
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: 1 단계, 이미지 1/1
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: 2 단계, 이미지 1/2 Decorative Light Fixture Lightbulb Replacement: 2 단계, 이미지 2/2
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: 3 단계, 이미지 1/1
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: 4 단계, 이미지 1/2 Decorative Light Fixture Lightbulb Replacement: 4 단계, 이미지 2/2
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: 5 단계, 이미지 1/1
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: 6 단계, 이미지 1/2 Decorative Light Fixture Lightbulb Replacement: 6 단계, 이미지 2/2
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: 7 단계, 이미지 1/2 Decorative Light Fixture Lightbulb Replacement: 7 단계, 이미지 2/2
    • Hold onto the fixture, and screw it back in with the screwdriver.
결승점
Jordan Parry
회원 가입일: 03/30/21
145 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G5, Gulbrandsen Spring 2021 UMass Dartmouth, Team S1-G5, Gulbrandsen Spring 2021 회원
UMASSD-GULBRANDSEN-S21S1G5
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 261
