주요 콘텐츠로 건너뛰기
Decorative Light Fixture Lightbulb Replacement
필요한 것
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: 1 단계, 이미지 1개 중 1개
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: 2 단계, 이미지 2개 중 1개 Decorative Light Fixture Lightbulb Replacement: 2 단계, 이미지 2개 중 2개
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: 3 단계, 이미지 1개 중 1개
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: 4 단계, 이미지 2개 중 1개 Decorative Light Fixture Lightbulb Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: 5 단계, 이미지 1개 중 1개
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: 6 단계, 이미지 2개 중 1개 Decorative Light Fixture Lightbulb Replacement: 6 단계, 이미지 2개 중 2개
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: 7 단계, 이미지 2개 중 1개 Decorative Light Fixture Lightbulb Replacement: 7 단계, 이미지 2개 중 2개
    • Hold onto the fixture, and screw it back in with the screwdriver.
결승점
작성자
1다른 기여자 명과 함께
Jordan Parry
회원 가입일: 03/30/21
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 44
전체 시간: 715
