주요 콘텐츠로 건너뛰기
Definitive Technology W7 Motherboard Replacement
필요한 것
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Definitive Technology W7 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Definitive Technology W7 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Definitive Technology W7 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Definitive Technology W7 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Definitive Technology W7 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
결론
작성자
2다른 기여자 명과 함께
Magnus Maillet
회원 가입일: 10/26/22
171 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 563
