주요 콘텐츠로 건너뛰기
Definitive Technology W7 Speaker Replacement
필요한 것
  1. Definitive Technology W7 Speaker Replacement, Speaker: 1 단계, 이미지 1개 중 1개
    • Use the metal spudger to pry off the panel at the top of the device.
    • The top panel has the device logo in the center.
    • Use the flat end of the metal spudger and place it between the gaps of the top panel and slowly pry the panel off.
  2. Definitive Technology W7 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen Phillips #0 screws.
  3. Definitive Technology W7 Speaker Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the black panel.
  4. Definitive Technology W7 Speaker Replacement: 4 단계, 이미지 2개 중 1개 Definitive Technology W7 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • After you remove the black panel, you will see that the device is covered with a gray mesh, secured with a drawstring.
    • Flick the switch on the middle of the lock down to loosen the sack.
  5. Definitive Technology W7 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • After you have flicked the switch loosen the sack and pull the sack down which will reveal the speaker.
  6. Definitive Technology W7 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
  7. Definitive Technology W7 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Gently lift the top cover off the device.
  8. Definitive Technology W7 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • If you now look inside the device, you will see the speaker which is the large cylinder on the inner side of the device.
  9. Definitive Technology W7 Speaker Replacement: 9 단계, 이미지 2개 중 1개 Definitive Technology W7 Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the four Phillips #0 screws around the speaker holding it in place.
    • Now lay the device on its side with the speaker facing upward, then unscrew the screws around the speaker.
  10. Definitive Technology W7 Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Stand the device upright and carefully pull the speaker out of the device with the wires still intact.
  11. Definitive Technology W7 Speaker Replacement: 11 단계, 이미지 1개 중 1개
    • Now grab the end of the wire connecting the device to the speaker itself.
    • Slowly and carefully pull the wires away from the speaker.
결론
작성자
1다른 기여자 명과 함께
Jamari Brewster
회원 가입일: 10/26/22
193 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 510
