주요 콘텐츠로 건너뛰기
Definitive Technology W7 Tweeters Replacement
필요한 것
  1. Definitive Technology W7 Tweeters Replacement, Access Panel: 1 단계, 이미지 1개 중 1개
    • Wedge the spudger in any of the four corners of the panel and apply downward pressure on the spudgers handle to pry the panel away from the speaker housing.
    • Repeat this procedure around the perimeter until the panel releases, then lift the panel up by hand.
  2. Definitive Technology W7 Tweeters Replacement: 2 단계, 이미지 2개 중 1개 Definitive Technology W7 Tweeters Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the thirteen 5 mm Phillips #0 screws.
    • Once all screws have been removed, gently pull up on the black panel to remove it from the top of the speaker.
  3. Definitive Technology W7 Tweeters Replacement: 3 단계, 이미지 3개 중 1개 Definitive Technology W7 Tweeters Replacement: 3 단계, 이미지 3개 중 2개 Definitive Technology W7 Tweeters Replacement: 3 단계, 이미지 3개 중 3개
    • The gray mesh bag covering the speaker will now be exposed.
    • Flick the switch on the middle of the lock down to loosen the sack.
    • Pull upwards on the locking mechanism to loosen the drawstring. Stop pulling when the mesh bag is loose enough that it can be pulled downwards.
  4. Definitive Technology W7 Tweeters Replacement: 4 단계, 이미지 2개 중 1개 Definitive Technology W7 Tweeters Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
    • Remove the black panel.
  5. Definitive Technology W7 Tweeters Replacement, Tweeters: 5 단계, 이미지 2개 중 1개 Definitive Technology W7 Tweeters Replacement, Tweeters: 5 단계, 이미지 2개 중 2개
    • Pull gently on the two red wires to disconnect them individually from the tweeter.
  6. Definitive Technology W7 Tweeters Replacement: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the three black screws attaching the tweeter to the housing.
  7. Definitive Technology W7 Tweeters Replacement: 7 단계, 이미지 1개 중 1개
    • Gently press down, from the outside of the case, on the tweeter to free it from the speaker case.
    • Ensure that you have an additional hand underneath the tweeter to catch it when it falls from the speaker case.
    • Repeat Steps 1-3 for the other tweeter if necessary.
결론
작성자
2다른 기여자 명과 함께
Brendan Thibault
회원 가입일: 10/26/22
339 평판
안내서 3개를 작성함
UMass Dartmouth, Team 2-5, Petersen Fall 2022 UMass Dartmouth, Team 2-5, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 335
