주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7569 Battery Replacement
필요한 것
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: 2 단계, 이미지 1/3 Dell   Inspiron  15-7569 Battery Replacement, Battery: 2 단계, 이미지 2/3 Dell   Inspiron  15-7569 Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Matthew Clements
회원 가입일: 10/03/17
546 평판
안내서 5개 작성하였습니다
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G4
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 34
전체 시간: 6,252
