주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7569 Motherboard Replacement
필요한 것
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 2 단계, 이미지 1/3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 2 단계, 이미지 2/3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: 2 단계, 이미지 3/3
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: 3 단계, 이미지 1/3 Dell   Inspiron  15-7569 Motherboard Replacement: 3 단계, 이미지 2/3 Dell   Inspiron  15-7569 Motherboard Replacement: 3 단계, 이미지 3/3
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: 4 단계, 이미지 1/3 Dell   Inspiron  15-7569 Motherboard Replacement: 4 단계, 이미지 2/3 Dell   Inspiron  15-7569 Motherboard Replacement: 4 단계, 이미지 3/3
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: 5 단계, 이미지 1/2 Dell   Inspiron  15-7569 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: 6 단계, 이미지 1/2 Dell   Inspiron  15-7569 Motherboard Replacement: 6 단계, 이미지 2/2
    • Gently remove the motherboard from the device.
결론
Matthew Clements
회원 가입일: 10/03/17
546 평판
안내서 5개 작성하였습니다
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 1,560
