주요 콘텐츠로 건너뛰기
Dell Inspiron 15-7569 Speaker Replacement
필요한 것
  1. Dell   Inspiron  15-7569 Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 Dell   Inspiron  15-7569 Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 Dell   Inspiron  15-7569 Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Speaker Replacement, Battery: 2 단계, 이미지 1/3 Dell   Inspiron  15-7569 Speaker Replacement, Battery: 2 단계, 이미지 2/3 Dell   Inspiron  15-7569 Speaker Replacement, Battery: 2 단계, 이미지 3/3
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
  3. Dell   Inspiron  15-7569 Speaker Replacement, Speaker: 3 단계, 이미지 1/3 Dell   Inspiron  15-7569 Speaker Replacement, Speaker: 3 단계, 이미지 2/3 Dell   Inspiron  15-7569 Speaker Replacement, Speaker: 3 단계, 이미지 3/3
    • Gently pull out white ribbon.
  4. Dell   Inspiron  15-7569 Speaker Replacement: 4 단계, 이미지 1/3 Dell   Inspiron  15-7569 Speaker Replacement: 4 단계, 이미지 2/3 Dell   Inspiron  15-7569 Speaker Replacement: 4 단계, 이미지 3/3
    • Lift the black and red wires connected to the speaker and unplug them from the motherboard.
결론
Matthew Clements
회원 가입일: 10/03/17
546 평판
안내서 5개 작성하였습니다
USF Tampa, Team S5-G4, Walkup Fall 2017 USF Tampa, Team S5-G4, Walkup Fall 2017 회원
USFT-WALKUP-F17S5G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 466
