주요 콘텐츠로 건너뛰기
Dell AC511 Volume Knob Replacement
필요한 것
  1. Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 1/3 Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 2/3 Dell AC511 Volume Knob Replacement, Front Panel: 1 단계, 이미지 3/3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Volume Knob Replacement: 2 단계, 이미지 1/2 Dell AC511 Volume Knob Replacement: 2 단계, 이미지 2/2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Volume Knob Replacement: 3 단계, 이미지 1/2 Dell AC511 Volume Knob Replacement: 3 단계, 이미지 2/2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Volume Knob Replacement, Volume Knob: 4 단계, 이미지 1/1
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
  5. Dell AC511 Volume Knob Replacement: 5 단계, 이미지 1/1
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
결론
William Cook
회원 가입일: 03/19/24
617 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 4-6, Shaddix Spring 2024 UMass Dartmouth, Team 4-6, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 13
