주요 콘텐츠로 건너뛰기
Dell Adamo 13 Dell Solid State Drive Replacement
필요한 것
  1. Dell Adamo 13 Dell Solid State Drive Replacement, Battery: 1 단계, 이미지 1/1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Dell Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Dell Solid State Drive Replacement: 3 단계, 이미지 1/1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Dell Solid State Drive Replacement, SSD: 4 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws securing the SSD to the motherboard.
결론
Joshua Turner
회원 가입일: 10/25/21
73 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G7
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 208
