주요 콘텐츠로 건너뛰기
Dell Adamo XPS Laptop Battery Replacement
  1. 주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Turn off the laptop before doing anything to the laptop.
    • Then turn the laptop around on its back.
    • On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
    • Then you have to push the computer battery towards the computer and rotate upwards.
    • Finally lift the battery out of the computer.
    • Align the battery with the battery slot before rotating it in place. There will be a snap.
    • Be careful snapping the battery in place don't use force to out in place.
결론
The battery will already be within the laptop, so no further steps needed.
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Melo-Pelaez
회원 가입일: 10/27/17
1,921 평판
안내서 9개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 221
