소개
We will be removing the Palm Rest panel from the computer which will allow us to access the internals of the computer.
필요한 것
1 단계 Removal of the Laptop Battery
주의: 1-2 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Then turn the laptop around on its back.
On the back of the computer there is a latch that you have to slide and hold in order to remove the battery.
Then you have to push the computer battery towards the computer and rotate upwards.
Finally lift the battery out of the computer.
Turn the computer around and remove the eighteen screws on the base cover.
Disconnect the function key cable from the connector on the system board.
Lift the connector latch that secures the touch pad cable to the touch pad connector and remove the cable.
다른 한 분이 해당 안내서를 완성하였습니다.
