소개
This guide will show the user how to replace a cracked, broken, or damaged computer base on a Dell Alienware 13 laptop.
필요한 것
Remove the small access panel using a heavy duty spudger.
Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
