주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Alienware 13 Computer Base Replacement
필요한 것
  1. Dell Alienware 13 Computer Base Replacement, Base Panel: 1 단계, 이미지 1개 중 1개
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Computer Base Replacement: 2 단계, 이미지 1개 중 1개
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Computer Base Replacement: 3 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 3 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
  4. Dell Alienware 13 Computer Base Replacement, Computer Base: 4 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement, Computer Base: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the battery cable terminal.
  5. Dell Alienware 13 Computer Base Replacement: 5 단계, 이미지 1개 중 1개
    • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
  6. Dell Alienware 13 Computer Base Replacement: 6 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 6 단계, 이미지 2개 중 2개
    • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
  7. Dell Alienware 13 Computer Base Replacement: 7 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 7 단계, 이미지 2개 중 2개
    • Using the pull tab, disconnect the black solid-state drive cable from the system board.
  8. Dell Alienware 13 Computer Base Replacement: 8 단계, 이미지 1개 중 1개
    • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
  9. Dell Alienware 13 Computer Base Replacement: 9 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 9 단계, 이미지 2개 중 2개
    • Lift up on the solid-state drive assembly to remove it from the computer base.
  10. Dell Alienware 13 Computer Base Replacement: 10 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 10 단계, 이미지 2개 중 2개
    • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
    • The latches that connect the cables to the system board are very delicate. Handle with care to avoid damaging them.
  11. Dell Alienware 13 Computer Base Replacement: 11 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 11 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 11 단계, 이미지 3개 중 3개
    • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
    • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
    • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
  12. Dell Alienware 13 Computer Base Replacement: 12 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 12 단계, 이미지 2개 중 2개
    • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
  13. Dell Alienware 13 Computer Base Replacement: 13 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 13 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 13 단계, 이미지 3개 중 3개
    • Turn the computer over and open the display as far as possible.
    • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
    • Gently lift the palm-rest assembly.
  14. Dell Alienware 13 Computer Base Replacement: 14 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 14 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 14 단계, 이미지 3개 중 3개
    • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
    • Lift the palm-rest assembly off the computer base.
  15. Dell Alienware 13 Computer Base Replacement: 15 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 15 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 15 단계, 이미지 3개 중 3개
    • Open the display as far as possible.
    • Remove (2) 3 mm Phillips head screws, using a Phillips head #0 screwdriver, that secure the hinge caps to the display hinges.
    • Slide and lift the hinge caps off the display hinges.
  16. Dell Alienware 13 Computer Base Replacement: 16 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 16 단계, 이미지 2개 중 2개
    • Close the display and turn the computer over.
    • Remove (1) 2 mm Phillips head screw, using a Phillips head # 0 screwdriver, that secures the wireless-card bracket to the wireless card.
  17. Dell Alienware 13 Computer Base Replacement: 17 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 17 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
  18. Dell Alienware 13 Computer Base Replacement: 18 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 18 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 18 단계, 이미지 3개 중 3개
    • Turn the computer over and open the display.
    • Peel off the adhesive tapes that secure the antenna cables to the system board.
    • Make note of how the cables are routed before removing any cables from their routing guide.
  19. Dell Alienware 13 Computer Base Replacement: 19 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 19 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 19 단계, 이미지 3개 중 3개
    • Lift the connector latch and disconnect the display cable from the system board.
    • Disconnect the logo-board cable from the system board.
    • Remove the antenna cables, display cable, and logo-board cable from the routing guides on the display hinges.
  20. Dell Alienware 13 Computer Base Replacement: 20 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 20 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 20 단계, 이미지 3개 중 3개
    • Remove (4) 8 mm Phillips head screws, using a Phillips # 1 screwdriver, that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  21. Dell Alienware 13 Computer Base Replacement: 21 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the (2) 6 mm Phillips head screws securing the power adapter port bracket with a #1 Phillips screwdriver.
    • Lift and remove the power adapter port bracket.
  22. Dell Alienware 13 Computer Base Replacement: 22 단계, 이미지 1개 중 1개
    • Lift up and remove the power adapter port from the computer base.
  23. Dell Alienware 13 Computer Base Replacement: 23 단계, 이미지 2개 중 1개 Dell Alienware 13 Computer Base Replacement: 23 단계, 이미지 2개 중 2개
    • Disconnect the speaker cable connector from the service board.
  24. Dell Alienware 13 Computer Base Replacement: 24 단계, 이미지 3개 중 1개 Dell Alienware 13 Computer Base Replacement: 24 단계, 이미지 3개 중 2개 Dell Alienware 13 Computer Base Replacement: 24 단계, 이미지 3개 중 3개
    • Remove (3) 6 mm Phillips head screws securing the service board with a #1 Phillips screwdriver.
    • Lift up on the service board assembly using a heavy duty spudger and slide the board towards the battery to remove from the base.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam Russell
회원 가입일: 09/26/16
898 평판
안내서 6개를 작성함
USF Tampa, Team 14-2, Eyestone Fall 2016 USF Tampa, Team 14-2, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G2
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 43
전체 시간: 1,281
