소개
In this guide, we will be showing you how to remove and replace the Hard Drive.
필요한 것
Using the pull tab, disconnect the hard-drive cable from the system board.
Remove the screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
Replace the screws that secure the hard-drive bracket to the hard-drive assembly.
Replace the screws that secure the hard-drive assembly to the computer base.
다른 한 분이 해당 안내서를 완성하였습니다.
