주요 콘텐츠로 건너뛰기
Dell Alienware 13 R3 Base Cover Replacement
필요한 것
  1. Dell Alienware 13 R3 Base Cover Replacement, Loosen the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Base Cover Replacement, Pry the Base Cover: 2 단계, 이미지 1개 중 1개
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Base Cover Replacement, Lift the Base Cover: 3 단계, 이미지 1개 중 1개
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Base Cover Replacement, Disconnect the Battery Cable: 4 단계, 이미지 1개 중 1개
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Base Cover Replacement, Slide the Tabs: 7 단계, 이미지 1개 중 1개
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Base Cover Replacement, Tighten the Five Captive Screws: 8 단계, 이미지 1개 중 1개
    • Tighten the five captive screws that secure the base cover to the computer base.
결론
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,831 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,991개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 726
