주요 콘텐츠로 건너뛰기
Dell Alienware 13 R3 Camera Replacement
필요한 것
  1. Dell Alienware 13 R3 Camera Replacement, Loosen the Screws: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Camera Replacement, Pry the Base Cover: 2 단계, 이미지 1/1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Camera Replacement, Lift the Base Cover: 3 단계, 이미지 1/1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Camera Replacement, Disconnect the Battery Cable: 4 단계, 이미지 1/1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Camera Replacement, Slide the Tabs: 7 단계, 이미지 1/1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Camera Replacement, Tighten the Five Captive Screws: 8 단계, 이미지 1/1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Camera Replacement, Align the Notch: 9 단계, 이미지 1/1
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
  8. Dell Alienware 13 R3 Camera Replacement, Lift the Wireless-Card Bracket: 10 단계, 이미지 1/1
    • Lift the wireless-card bracket off the wireless card.
  9. Dell Alienware 13 R3 Camera Replacement, Disconnecting the Antenna Cables: 11 단계, 이미지 1/1
    • Disconnect the antenna cables from the wireless card.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
    • Slide the NEW wireless card at an angle into the wireless-card slot.
    • Connect the antenna cables to the wireless card.
  10. Dell Alienware 13 R3 Camera Replacement, Align the Screw Hole: 15 단계, 이미지 1/1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  11. Dell Alienware 13 R3 Camera Replacement, Replace the Screw: 16 단계, 이미지 1/1
    • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
  12. Dell Alienware 13 R3 Camera Replacement, Popping up the Memory Module: 17 단계, 이미지 1/1
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  13. Dell Alienware 13 R3 Camera Replacement, Remove the Memory Module: 18 단계, 이미지 1/1
    • Slide and remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
  14. Dell Alienware 13 R3 Camera Replacement, Press the Memory Module Down: 20 단계, 이미지 1/1
    • Press the memory module down until it clicks into place.
  15. Dell Alienware 13 R3 Camera Replacement, Remove the Screw: 21 단계, 이미지 1/1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  16. Dell Alienware 13 R3 Camera Replacement, Lift and Slide the Solid-State Drive: 22 단계, 이미지 1/1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  17. Dell Alienware 13 R3 Camera Replacement, Press the Memory Module: 24 단계, 이미지 1/1
  18. Dell Alienware 13 R3 Camera Replacement, Remove the Screws: 25 단계, 이미지 1/1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  19. Dell Alienware 13 R3 Camera Replacement, Using a Plastic Scribe: 26 단계, 이미지 1/1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  20. Dell Alienware 13 R3 Camera Replacement, Sliding the Rear-I/O: 28 단계, 이미지 1/1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  21. Dell Alienware 13 R3 Camera Replacement, Remove the Screws: 30 단계, 이미지 1/1
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  22. Dell Alienware 13 R3 Camera Replacement, Remove the Screw: 31 단계, 이미지 1/1
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  23. Dell Alienware 13 R3 Camera Replacement, Remove the Two Screws: 32 단계, 이미지 1/1
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  24. Dell Alienware 13 R3 Camera Replacement, Lift the Computer Base: 33 단계, 이미지 1/1
    • Lift the computer base from the palm-rest assembly.
  25. Dell Alienware 13 R3 Camera Replacement, Align the Screw Holes: 34 단계, 이미지 1/1
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  26. Dell Alienware 13 R3 Camera Replacement, Disconnecting the Coin-Cell Battery: 38 단계, 이미지 1/1
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  27. Dell Alienware 13 R3 Camera Replacement, Peeling the Coin-Cell Battery: 39 단계, 이미지 1/1
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  28. Dell Alienware 13 R3 Camera Replacement, Adhere the Coin-Cell Battery: 40 단계, 이미지 1/1
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
  29. Dell Alienware 13 R3 Camera Replacement, Peeling the Keyboard Connector: 42 단계, 이미지 1/1
  30. Dell Alienware 13 R3 Camera Replacement, Lifting the Battery: 43 단계, 이미지 1/1
    • Lift the battery off the palm-rest assembly.
  31. Dell Alienware 13 R3 Camera Replacement, Placing the New Battery: 44 단계, 이미지 1/1
    • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
    • Using the alignment post, place the NEW battery on the palm-rest assembly.
  32. Dell Alienware 13 R3 Camera Replacement, Adhering the Keyboard: 45 단계, 이미지 1/1
    • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
  33. Dell Alienware 13 R3 Camera Replacement, Disconnect the Left-Fan Cable: 46 단계, 이미지 1/1
    • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
    • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
    • Disconnect the left-fan cable from the system board.
  34. Dell Alienware 13 R3 Camera Replacement, Disconnecting the Right-Fan Cable: 47 단계, 이미지 1/1
    • Disconnect the right-fan cable from the system board.
  35. Dell Alienware 13 R3 Camera Replacement, Remove the Seven Screws: 48 단계, 이미지 1/1
    • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Lift the heat-sink assembly off the system board.
  36. Dell Alienware 13 R3 Camera Replacement, Align the Screw Holes: 50 단계, 이미지 1/1
    • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
    • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Connect the right-fan cable to the respective connector on the system board.
    • Connect the left-fan cable to the respective connector on the system board.
  37. Dell Alienware 13 R3 Camera Replacement, Turn the Computer Over: 54 단계, 이미지 1/1
    • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
    • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
    • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
    • CAUTION: Place the computer on a clean, flat surface.
    • Turn the computer over.
  38. Dell Alienware 13 R3 Camera Replacement, Disconnecting the Logo-Board Cable: 55 단계, 이미지 1/1
    • Disconnect the logo-board cable from the system board.
  39. Dell Alienware 13 R3 Camera Replacement, Disconnecting the Power-Button Board Cable: 56 단계, 이미지 1/1
    • Using the pull-tab, disconnect the power-button board cable from the system board.
  40. Dell Alienware 13 R3 Camera Replacement, Open the Latch: 57 단계, 이미지 1/1
    • Open the latch and disconnect the display cable from the system board.
  41. Dell Alienware 13 R3 Camera Replacement, Turn the Computer Over: 58 단계, 이미지 1/1
  42. Dell Alienware 13 R3 Camera Replacement, Remove the Screw: 59 단계, 이미지 1/1
    • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
    • Disconnect the power-adapter port cable from the system board.
  43. Dell Alienware 13 R3 Camera Replacement, Disconnect the Speaker Cable: 61 단계, 이미지 1/1
    • Disconnect the speaker cable from the system board.
  44. Dell Alienware 13 R3 Camera Replacement, Open the Latch: 62 단계, 이미지 1/1
    • Open the latch and disconnect the keyboard cable from the system board.
  45. Dell Alienware 13 R3 Camera Replacement, Open the Latch: 63 단계, 이미지 1/1
    • Open the latch and disconnect the keyboard-backlight cable from the system board.
  46. Dell Alienware 13 R3 Camera Replacement, Disconnect the Touch-Pad Cable: 64 단계, 이미지 1/1
    • Open the latch and disconnect the touch-pad cable from the system board.
  47. Dell Alienware 13 R3 Camera Replacement, Remove the Screw: 65 단계, 이미지 1/1
  48. Dell Alienware 13 R3 Camera Replacement, Remove the two Screws: 66 단계, 이미지 1/1
    • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
  49. Dell Alienware 13 R3 Camera Replacement, Lift the System Board: 67 단계, 이미지 1/1
    • Lift the system board off the palm-rest assembly.
  50. Dell Alienware 13 R3 Camera Replacement, Align the Screw Holes: 68 단계, 이미지 1/1
    • CAUTION: Ensure that no cables are under the system board.
    • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
  51. Dell Alienware 13 R3 Camera Replacement, Replace the Two Screws: 69 단계, 이미지 1/1
    • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
  52. Dell Alienware 13 R3 Camera Replacement, Align the Screw Hole: 70 단계, 이미지 1/1
    • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
  53. Dell Alienware 13 R3 Camera Replacement, Replace the Screw: 71 단계, 이미지 1/1
    • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
    • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
  54. Dell Alienware 13 R3 Camera Replacement, Sliding the Keyboard-Backlight: 73 단계, 이미지 1/1
    • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
  55. Dell Alienware 13 R3 Camera Replacement, Slide the Keyboard Cable: 74 단계, 이미지 1/1
    • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
    • Connect the speaker cable to the system board.
    • Connect the power-adapter port cable to the system board.
  56. Dell Alienware 13 R3 Camera Replacement, Turn the Computer Over: 77 단계, 이미지 1/1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
    • Connect the power-button board cable to the system board.
    • Connect the logo-board cable to the system board.
  57. Dell Alienware 13 R3 Camera Replacement, Remove the Antenna Cables: 81 단계, 이미지 1/1
  58. Dell Alienware 13 R3 Camera Replacement, Remove the Logo-Board Cable: 82 단계, 이미지 1/1
    • Remove the logo-board cable from the routing guides on the palm-rest assembly.
  59. Dell Alienware 13 R3 Camera Replacement, Remove the Display Cable: 83 단계, 이미지 1/1
    • Remove the display cable from the routing guides on the palm-rest assembly.
  60. Dell Alienware 13 R3 Camera Replacement, Turn the Computer Over: 84 단계, 이미지 1/1
  61. Dell Alienware 13 R3 Camera Replacement, Remove the Four Screws: 85 단계, 이미지 1/1
    • Remove the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  62. Dell Alienware 13 R3 Camera Replacement, Lifting the Display Assembly: 86 단계, 이미지 1/1
    • Lift the display assembly off the palm-rest assembly.
  63. Dell Alienware 13 R3 Camera Replacement, Remove the Cables: 87 단계, 이미지 1/1
    • Remove the cables from the routing holes on the palm-rest assembly.
  64. Dell Alienware 13 R3 Camera Replacement, Placing the Display: 88 단계, 이미지 1/1
    • Place the display assembly on a clean, flat surface.
  65. Dell Alienware 13 R3 Camera Replacement, Route the Cables: 89 단계, 이미지 1/1
    • Route the cables through the routing holes on the palm-rest assembly.
  66. Dell Alienware 13 R3 Camera Replacement, Align the Screw Holes: 90 단계, 이미지 1/1
    • Align the screw holes on the display hinges with the screw holes on the palm- rest assembly.
  67. Dell Alienware 13 R3 Camera Replacement, Replace the Four Screws: 91 단계, 이미지 1/1
    • Replace the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
  68. Dell Alienware 13 R3 Camera Replacement, Turn the Computer Over: 92 단계, 이미지 1/1
  69. Dell Alienware 13 R3 Camera Replacement, Route the Logo-Board Cable: 93 단계, 이미지 1/1
    • Route the logo-board cable through the routing guides on the palm-rest assembly.
  70. Dell Alienware 13 R3 Camera Replacement, Route the Antenna Cables: 94 단계, 이미지 1/1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
    • Using your fingertips, carefully pry up the inside edges of the display bezel.
  71. Dell Alienware 13 R3 Camera Replacement, Lift the Display Bezel: 96 단계, 이미지 1/1
    • Carefully lift the display bezel and turn it over.
  72. Dell Alienware 13 R3 Camera Replacement, Disconnect the Alien Head Logo: 97 단계, 이미지 1/1
    • Open the latch and disconnect the alien head logo-board cable from the logo board.
  73. Dell Alienware 13 R3 Camera Replacement, Peeling the Tape: 98 단계, 이미지 1/1
    • Peel off the tape that secures the logo-board cable to the logo board and disconnect the logo-board cable from the logo board.
  74. Dell Alienware 13 R3 Camera Replacement, Lift the Display Bezel: 99 단계, 이미지 1/1
    • Lift the display bezel off the display assembly.
  75. Dell Alienware 13 R3 Camera Replacement, Place the Display Assembly: 100 단계, 이미지 1/1
    • Connect the logo-board cable to the logo board.
  76. Dell Alienware 13 R3 Camera Replacement, Adhering the Tape: 102 단계, 이미지 1/1
    • Adhere the tape that secures the logo-board cable to the logo board.
  77. Dell Alienware 13 R3 Camera Replacement, Slide the Logo Board Cable: 103 단계, 이미지 1/1
    • Slide the alien head logo-board cable into the logo board and close the latch to secure the cable.
    • Carefully turn the display bezel over.
  78. Dell Alienware 13 R3 Camera Replacement, Align the Bezel: 105 단계, 이미지 1/1
    • Align the display bezel with the display back-cover and antenna assembly and gently snap the display bezel into place.
  79. Dell Alienware 13 R3 Camera Replacement, Pry the Camera Module: 106 단계, 이미지 1/1
    • Using a plastic scribe, pry the camera module from the display back-cover and antenna assembly.
  80. Dell Alienware 13 R3 Camera Replacement, Peel the Tape: 107 단계, 이미지 1/1
    • Peel the tape that secures the camera cable to the camera module and disconnect the camera cable from the camera module.
  81. Dell Alienware 13 R3 Camera Replacement, Lift the Camera Module: 108 단계, 이미지 1/1
    • Lift the camera module from the display back-cover and antenna assembly.
  82. Dell Alienware 13 R3 Camera Replacement, Adhere the Camera Module: 109 단계, 이미지 1/1
    • Using the alignment posts, adhere the NEW camera module to the display back-cover and antenna assembly.
  83. Dell Alienware 13 R3 Camera Replacement, Connect the Camera Cable: 110 단계, 이미지 1/1
    • Connect the camera cable to the camera module.
  84. Dell Alienware 13 R3 Camera Replacement, Adhere the Tape: 111 단계, 이미지 1/1
    • Adhere the tape that secures the camera cable to the camera module.
결승점
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
I am so confused by this. I clicked on a link to show how to replace the webcam, this goes through seemingly everything and I don’t know how best to follow. I mean it shows you have to remove the battery, which I get, but then immediately says to re-connect it? Surely I should re-connect once I have finished?
Kelvin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 278
