주요 콘텐츠로 건너뛰기
Dell Alienware 13 R3 Coin-Cell Battery Replacement
필요한 것
  1. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Loosen the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Pry the Base Cover: 2 단계, 이미지 1개 중 1개
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift the Base Cover: 3 단계, 이미지 1개 중 1개
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Disconnect the Battery Cable: 4 단계, 이미지 1개 중 1개
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Slide the Tabs: 7 단계, 이미지 1개 중 1개
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Tighten the Five Captive Screws: 8 단계, 이미지 1개 중 1개
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screw: 9 단계, 이미지 1개 중 1개
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  8. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift and Slide the Solid-State Drive: 10 단계, 이미지 1개 중 1개
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  9. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Press the Memory Module: 12 단계, 이미지 1개 중 1개
    • Press the memory module down until it clicks into place.
  10. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screws: 13 단계, 이미지 1개 중 1개
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  11. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Using a Plastic Scribe: 14 단계, 이미지 1개 중 1개
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  12. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Sliding the Rear-I/O: 16 단계, 이미지 1개 중 1개
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  13. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screws: 18 단계, 이미지 1개 중 1개
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  14. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Screw: 19 단계, 이미지 1개 중 1개
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  15. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Remove the Two Screws: 20 단계, 이미지 1개 중 1개
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  16. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Lift the Computer Base: 21 단계, 이미지 1개 중 1개
    • Lift the computer base from the palm-rest assembly.
  17. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Align the Screw Holes: 22 단계, 이미지 1개 중 1개
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  18. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Disconnecting the Coin-Cell Battery: 26 단계, 이미지 1개 중 1개
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  19. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Peeling the Coin-Cell Battery: 27 단계, 이미지 1개 중 1개
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  20. Dell Alienware 13 R3 Coin-Cell Battery Replacement, Adhere the Coin-Cell Battery: 28 단계, 이미지 1개 중 1개
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
결론
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,831 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,991개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 35
전체 시간: 1,696
