소개
In this guide, we will show you how to remove and replace the Display Bezel.
필요한 것
Loosen the five captive screws that secure the base cover to the computer base.
Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
Using a plastic scribe, disconnect the battery cable from the system board.
Press and hold the power button for five seconds to ground the system board.
Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
Tighten the five captive screws that secure the base cover to the computer base.
Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
Align the notch on the wireless card with the tab on the wireless-card slot.
Slide the NEW wireless card at an angle into the wireless-card slot.
Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
Remove the screw (M2x3) that secures the solid-state drive to the computer base.
Lift and slide the solid-state drive from the solid-state drive slot.
Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
Disconnect the coin-cell battery cable from the system board.
Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
Using the alignment post, place the NEW battery on the palm-rest assembly.
Adhere the keyboard connector that secures the battery to the palm-rest assembly.
In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
Connect the right-fan cable to the respective connector on the system board.
Connect the left-fan cable to the respective connector on the system board.
Disconnect the logo-board cable from the system board.
Using the pull-tab, disconnect the power-button board cable from the system board.
Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
Disconnect the power-adapter port cable from the system board.
Open the latch and disconnect the keyboard-backlight cable from the system board.
Open the latch and disconnect the touch-pad cable from the system board.
Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
Slide the display cable into the connector on the system board and close the latch to secure the cable.
Connect the power-button board cable to the system board.
Remove the antenna cables from the routing guides on the palm-rest assembly.
Remove the logo-board cable from the routing guides on the palm-rest assembly.
Remove the display cable from the routing guides on the palm-rest assembly.
Remove the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
Align the screw holes on the display hinges with the screw holes on the palm- rest assembly.
Replace the four screws (M2.5x6L) that secure the display assembly to the palm-rest assembly.
Route the logo-board cable through the routing guides on the palm-rest assembly.
Route the antenna cables through the routing guides on the palm-rest assembly.
Using your fingertips, carefully pry up the inside edges of the display bezel.
Open the latch and disconnect the alien head logo-board cable from the logo board.
Peel off the tape that secures the logo-board cable to the logo board and disconnect the logo-board cable from the logo board.
Slide the alien head logo-board cable into the logo board and close the latch to secure the cable.
Align the display bezel with the display back-cover and antenna assembly and gently snap the display bezel into place.
