주요 콘텐츠로 건너뛰기
Dell Alienware 14 Battery Replacement
필요한 것
  1. Dell Alienware 14 Battery Replacement, Close the Display: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Battery Replacement, Remove the Screws: 2 단계, 이미지 1/2 Dell Alienware 14 Battery Replacement, Remove the Screws: 2 단계, 이미지 2/2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Battery Replacement, Slide and Lift the Base Cover: 3 단계, 이미지 1/1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Battery Replacement, Align the Tabs: 4 단계, 이미지 1/1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Battery Replacement, Replace the Screws: 5 단계, 이미지 1/1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Battery Replacement, Turn the Computer Over: 6 단계, 이미지 1/1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Battery Replacement, Disconnecting the Battery Cable: 7 단계, 이미지 1/1
  8. Dell Alienware 14 Battery Replacement, Remove the Screws: 8 단계, 이미지 1/1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Battery Replacement, Using the Battery Cable: 9 단계, 이미지 1/1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Battery Replacement, Turn the Computer Over: 10 단계, 이미지 1/1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Battery Replacement, The Power Button: 11 단계, 이미지 1/1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Battery Replacement, Align the Tabs: 13 단계, 이미지 1/1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Battery Replacement, Align the Screw Holes: 14 단계, 이미지 1/1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Battery Replacement, Replace the Screws: 15 단계, 이미지 1/1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Battery Replacement, Connect the Battery Cable: 16 단계, 이미지 1/1
    • Connect the battery cable to the system-board connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,309 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,984개 작성하였습니다
댓글 한 개
I took my battery out and lost it. I didn't record the part number. Does anybody around here happen to have it handy?
ignacio - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 17
전체 시간: 1,986
